Author Topic: «Top 25 Most Played» Playlist  (Read 1529 times)
Ricardo Casares
I accidentally deleted the «Top 25 Most Played» playlist. Already checked the Fandom page about MusicBee and no help, I also tried a lot of combinations on the Auto-Playlist settings and I wasn't able to set it back. What are the values that I have to put on the Auto-Playlist settings to create the «Top 25 Most Played»?
Sorry if this is a stupid question but I'm a rookie at this. Many thanks!
Last Edit: March 03, 2021, 11:43:58 PM by Ricardo Casares
The criterion can be left at just artist starts with blank or whatever the default is.
Then, at the bottom, check next to limit to 25 items selected by most often played.
This seems like a good candidate for the burgeoning FAQ section of the forum🤣
Ricardo Casares
Hello frankz,
I followed your instructions and I still wasn't able to replicate it or at least the track play count that was on the original playlist doesn't appear.
Here's the screenshots: https://imgur.com/a/ztWOMR4
Thank you!
You need to right click the header row in the playlist and bring up the menu to select the fields you want to display in the playlist.
You should spend some time at the wiki to learn the basics of MusicBee, it'll pay off in the long run.
Have a great day!
Ricardo Casares
Thanks, it worked.
Last Edit: March 05, 2021, 12:23:36 PM by Ricardo Casares
