Author Topic: playlist  (Read 960 times)
mgb
Can I add tracks to an imported playlist mb can't find files but they are in there.
I have removed the 'poll' you posted since it wasn't relevant to your question.
ma_t14
If you right-click > Edit on any track that appears to be missing, under the "Properties" tab you can see the location of the file the playlist is pointing to. It's likely that the path of the track has been changed and now it can't find the track at its original location..
Or alternatively open the playlist file with a text editor to check how it's formatted and how it calls the music files
Last Edit: March 02, 2021, 08:36:59 PM by ma_t14
