Before you continue any further, are you using the Portable version? If not, do so. Then the next time you want to move MB, you just copy the entire MB directory to a flash drive and copy it to the new location.
And before you start adding artwork, you need to make sure your tracks are tagged properly. Incorrect, or no, tagging will get you poor results.
