Author Topic: [3.4.7708 P] Adjusting track numbers in "Albums" view shifts focused track wrong  (Read 1105 times)
amosmyn
Version: 3.3.7491 Store
    AND 3.4.7708 P
Note: Auto-organizer is enabled
Adjusting track numbers causes MusicBee to skip over tracks. Presumably this is because MusicBee is following the current order of the tracks, which changes as adjustments are made, instead of a temporary address list.
Here's the process: Add the track number, then hit the 'next track' arrow.
Last Edit: February 25, 2021, 03:20:37 PM by amosmyn
amosmyn
Just an update:
I've just tested this on the latest portable forum build and it still happens, but...
It seems that this problem is specific to the Album Cover view, as it doesn't occur in the album and tracks view.
Album and Tracks does this instead:
Last Edit: February 24, 2021, 09:41:02 PM by amosmyn
amosmyn
Hello, can someone confirm that this occurs on their system? It should be easy to replicate.
Change to album cover view, start with a record with no track numbers and at least 5 tracks, and then add the track numbers one by one using the "next" key.
gobater
I recall having the same issue in the past. Not sure if still there in 3.4.7732 P...
In the passt pressing F5 solved the problem, but somehow still annoying...
