Author Topic: Color format function to follow background colour in virtual tags  (Read 937 times)
SonicRings
https://getmusicbee.com/forum/index.php?topic=24595.0
Related to the above post, I found myself in a situation where I'd like to set a colour, but said colour is not visible when the background is light. The software automatically changes text from black to white depending on the colour of the bakground, so I believe it should allow you to individually change which colour it changes it to instead of black or white separately.
That way, I can change the colour to, for example, green when the background is dark, and blue when the background is light.
Apologies if this is already possible, do let me know how to do it if so.
