Author Topic: reverb and echo  (Read 230 times)
lostb053
umm, i am new to forum so my request might seem sort of naive
but i will request anyway
actually i have been using musicbee for like 2-4 years thinking it is best player out there
when suddenly somebody told me aimp has better features (ofc not, i dont like the feel)
i tried aimp but it was not so customizable as musicbee and plugin support was not really good as compared to musicbee
tho only features that aimp has and musicbee dont are the reverb and echo
tho musicbee supports winamp plugin but most of those are not that helpful
can i get them as native features
edit: as per this post
         new release will get pitch control, thus i edited title and content a bit
Last Edit: February 10, 2021, 12:44:48 PM by lostb053
This was enabled in July of last year. If you're looking for the feature you should update to the latest 3.4 version available from my signature.
Check out the MusicBee Wiki.
  • Editor
lostb053:  The new enhanced pitch control does not include reverb or echo, but you can find all kinds of free VST plugins that offer that;  first you would need to install the MusicBee VST host plugin (https://getmusicbee.com/addons/plugins/16/vst-effects-support/) and be sure bass_vst.dll exists in the main MusicBee directory (if not you can download it here: http://www.un4seen.com/download.php?z/5/bass_vst24).
lostb053
Yes
I am using 3.4 right now
And it has pitch
Thank you
lostb053
Thanx a lot
Will try it soon and will reply again if it works 😃
