Author Topic: Adding Discogs Releases to MusicBrainz  (Read 5601 times)
manrae
For whatever reason, I couldn't turn up your specific example, either. I don't know all the details on the API or why it wouldn't find it (I get results from Discogs for plenty of other albums), but I added it to MusicBrainz for you. A search for just Chalie Boy brings it up for me.
Oh wow, thank you very much!  :)
You're welcome :D  That's something you can do yourself, btw. Anybody can make a MusicBrainz account, and there's a discogs import script you can use if you're willing to fiddle a little with browser extensions.
manrae
Sure, is there a step-by-step guide? I had no idea that I could edit the MusicBrainz website
I just created a musicbrainz account  8)
It's not quite step-by-step, but here's a place to start:
https://beta.musicbrainz.org/doc/Introduction_to_Editing
https://community.metabrainz.org
Discogs script: https://github.com/murdos/musicbrainz-userscripts/blob/master/discogs_importer.user.js
Depending on your browser, you'll need something like Tampermonkey or Violentmonkey to install it, but once it's there, there should be a button on each discogs release for importing to MusicBrainz (it also adds links to existing MusicBrainz pages for artists and so on, if they exist and are linked to discogs).
manrae
I just tested it out, tried updating my library with my new edit, and everything worked fine
Thanks a lot!
Thanks a lot!
:D Welcome to the rabbit hole!
