Author Topic: Dropping files into Muscbee  (Read 7828 times)
milos
What format does the program accept as a drop? When trying to drop files as FileDrop the program shows crossed circle. Other programs don't have issues accepting dropped files from my file manager
string dataFormat = DataFormats.FileDrop;
DataObject obj = new DataObject();
obj.SetFileDropList(path_to_file);
DragDrop.DoDragDrop(this, obj, DragDropEffects.All);
How was MB installed? (Installer, Portable, Store)
MB accepts just about any audio file. Preferences > General > File types.
So that begs the question - what file type are you dropping?
You also may not have permission to access the directory where you're dropping.
milos
Thanks for reply @phred; I've actually got it...
so Musicbee won't accept dropped mp3 file if I use
or
DragDrop.DoDragDrop(this, obj, DragDropEffects.Copy | DragDropEffects.Move);
regardless if in addition I hold ctrl/shift/alt
but it will accept
DragDrop.DoDragDrop(this, obj, DragDropEffects.Copy);
I was afraid I'd have to deal with some complicated  memorystreams, so this is good.
Cheers
