Author Topic: Download lyrics to a specific folder  (Read 1428 times)
tumuyan
I wish I could set a folder for downloading lyrics,
 I don't want music files and lyrics files in the same folder, and I don't want to merge the lyrics files into the music files
The minilyrics helper plugin allows for this.  Obviously, you'd need to install Minilyrics and use it to download lyrics rather than MB's process to accomplish this, but it may be worth it if it means a lot to you to be able to do what you want.
Minilyrics offers TXT (static) and LRC (synchronized) lyrics.
Have a nice day!
tumuyan
I have tried minilyrics, but I find it also has some problems.
1. it could only search lyrics from google (I could not change to other site to search) and it always gets null result. (maybe cause of my network),
2. it could show lyric in itself windows or float like  karaoke, but some times I use MB with theater mode and perfect a lrc panel in MB
I think add a option to define lrc folder is easy and effective
