Author Topic: OUTPUT TO button  (Read 1030 times)
Mr. Be
hi there
like in subject:
separate OUTPUT TO button on player controls to have direct access to it with one click less :)
thank you
That is not likely to happen, since it wouldn't work for any existing skins.
The most likely implementation would be to have shortcuts available for that in the toolbar.
I believe there have been wishes for that in the past. (not sure though at the moment)
You could see if you can find them and support them, or create a new one.
(I myself would very much like to be able to simply toggle between two different output configurations)
