Author Topic: Spectrum Analyzer in Theater Mode  (Read 857 times)
will1966
Is there a way to turn off the spectrum analyzer in Theater Mode? I love it otherwise, but the analyzer is distracting.
Theatre Modes are specifically created and typically not subject to regular MB configuration. I suggest you post your question in the thread for the theatre mode you're using to see if the author can make a suggestion of modification.
It would not be not hard to remove the visualiser element from the .xml file yourself. The files are found in Plugins/TheaterMode.List/*.xml
