Author Topic: No search results for "mp3", and "m4a", while "flac" shows results.  (Read 1010 times)
stardot
In my library there are mp3, m4a, and flac files. When I type "mp3", and "m4a" in search field, however, no results show. That is not the case for "flac", which does show results.
What is the reason for this? And how to show results?
Thanks
Testing a custom search works as expected.
".Ext is mp3"
vincent kars
If I type mp3 in the search box I do get 1 result instead of the expected 5173
This is because there is a text with mp3 in it in the comment tag.
This is when using "search all fields"
When using  "search all fields" + Filename, I get the right number
Obvious "search all fields" doesn't include filename or the .Ext
stardot
".Ext is mp3"
Right, I did not know about custom search. Thanks.
stardot
@vincent kars Thanks. I did not know about different options of search. Now it works with the "+ Filename."
Why did the "search all fields" work for "flac" though?
