Author Topic: Void (series)  (Read 34642 times)
A series of coloured skins with a minimal style player panel.
download Void Black
download Void Blue
download Void Red
download Void Green
Last Edit: June 11, 2022, 10:26:56 AM by hiccup
updated
Some minor alignment improvements on the player panel.
Updated
Fixed an oversight and made a small improvement on the Music Explorer panel.
Updated
fixed an oversight with toolbar buttons
Johan_A_M
Really like this skin @Hiccup, using it since you released it!
Two minor points. I'd like to change the color of the text down in the status bar, as I find it a bit too difficult to read. Also, I'd like to experiment with the red which I also find a bit too difficult to read against the gray (I remote-login to the Musicbee computer, so the resolution gets a bitt distorted). Is there anyway of doing that?
Once again, thanks for a great theme!
That's nice to hear.
The reds are indeed a bit difficult here. Sometimes I think they are too bright, and other times that they are too dark.
You can change most of the colours (except the ones in the player panel and icons) of a bitmap (xmlc) skin by creating a piggy-back skin for it:
https://getmusicbee.com/forum/index.php?topic=29815.0
Johan_A_M
Thanks Hiccup, I'll experiment a bit and get back to you if I find something nice. Thanks again for a nice skin!
Also consider the impact that a computer display and it's settings have.
Things like adjusting the colour balance or gamma can make a big difference, and as an f.lux user, the reds really pop-out later in the evening.
Johan_A_M
Ok, so even with Clear Type off, a color picker like the Instant Color Picker was not able to pick the exact color of the font in the status bar. mostl I get 110,110,x, but when searching in Sample Skin, that only points me to
<element id="Panel.StatusBar.Default" bg="226,227,228" fg="110,110,111" bdr="212,213,214" />
 <element id="Panel.StatusBarControl.Default" fg="110,110,112" />
and when changing these fg (foreground I guess), it doesn't seem to be the text. You don't happen to remember if thereäs any other way/element adjusting fontcolor? Maybe the font color in the status bar is the same as the font color somewhere else?
Ok, so even with Clear Type off, a color picker like the Instant Color Picker was not able to pick the exact color of the font in the status bar. mostl I get 110,110,x, but when searching in Sample Skin, that only points me to…
Maybe I am misunderstanding what you are doing, but the idea is that you pick the colour of the element using the Sample Skin.
If we are talking about the same statusbar text (player panel positioned at the bottom, the statusbar right above it) you should get 18,151,133
That matches "Panel.StatusBarInPanel.Default" in the Sample Skin xml.
So then you add that element to your piggy-back skin and change the colours to your liking.
PS, colour-picking pro tip: you can get the right colour picked with leaving cleartype on, if you for example pick the middle part of an horizontal part of e.g. the number 4.
Johan_A_M
Well that was certainly a pro tip!
I must be doing something wrong. Using youir method, I was able to exchange the red for a rather pleasant blue that works both with the gray and on my monitor. WIll change the rest of the reds later. However, the status bar text (the one you mentioned) does not change. Using Panel.StatusBarInPanel.Default, I've tried to switch all variables (bg, bg2, fg, bdr) to distinct colours, but it's still gray as you can see. Pretty certain the error is on my side, and wouldn't be surprised if it's a simple one...
https://imgur.com/a/qRr9JLP
Last Edit: March 26, 2021, 04:38:18 AM by Johan_A_M
I don't know why it doesn't work for you, this works for me:
<root dependsOn="Void dark.xmlc">
 <element id="Content[TrackDetail].Body.Highlight" bg="31,78,121"  bdr="81,140,194" fg="237,249,254" />
 <element id="Panel.StatusBarInPanel.Default" bg="48,48,48" bg2="48,48,48" fg="50,250,50" bdr="48,48,48" />
</root>
Johan_A_M
</root>
Really strange, I created a new .xml with only this code, but it still doesn't work on the status bar. However, thanks for trying out to help!
Strange indeed.
The only thing I can think of at the moment is that you have a different panel configuration than I.
And/or something went wrong in the colour-picking Sample skin process.
Are you using the same MB installation for using Sample Skin and for Void 'blue'?
I.e. not using two different portable installs with perhaps different layouts, but you are switching between these skins in the same MB setup?
there are 2 relevant elements depending on the location of the status bar with respect to the player controls panel
Panel.StatusBarBelowPlayer.Default
