Author Topic: Tracks Analysis and Replay Gain...  (Read 701 times)
stardot
If I analyze tracks, will it only write the tracks' gain in the tags, or will it, also, change the gain they are played on? If write tags only, how can I play the adjusted gain?
My question maybe not be understandable because I did not yet comprehend the whole gain concept and how to apply it.
Thanks
Controls->(Replay Gain Off / Smart Gain / Track Gain Only / Album Gain Only)
vincent kars
