Author Topic: the Alt + Space shortcut to manage the window by keyboard does not work  (Read 1053 times)
Aminpcr
Hello everyone. and thanks to all the devs.
i have found a weird thing in app behavior.
on any theme other than " Windows Theme ", the Alt + Space shortcut to manage main and compact player windows does not work. i use it to quickly minimise main player. window is in focus of course.
mini player does not have such window shortcut even with windows theme.
i searched for the keyword minimize among already reported bugs and coulnt find any match.
for now im only using windows theme to have this feature.
thank in advance.
This is not a bug.
It seems you are confusing Windows panel shortcuts with specific views that other applications may or may not provide.
For MusicBee you should look at Preferences > Hotkeys if you want to define hotkeys for different views.
Aminpcr
thanks. i dont know why i had not found it before in the hotkey list. damn.
its simply named Application Minimise/restore :D
