Author Topic: Sync Play Count Off  (Read 639 times)
Esnaider
When I sync the play count from Last.fm there's two tracks that I have barely play more than a couple times, but the play count says over two hundred times, I keep resetting and syncing,even deleting the tracks and adding them again and nothing works
Delete the file %AppData%\Local\MusicBee\InternalCache\LastFmPlayCountCache.dat, reset the play counts, and sync again.  Otherwise, you're just re-reading the same bad old data and only updating what's new.
