Author Topic: Tag Handling - 'send to clipboard' tags field converts character across sessions  (Read 1168 times)
zkhcohen
v3.4.7692  P
Specifically, I use the 'send to clipboard' tags field with tabs copied as the actual character, rather than the non-working HTML code, escape sequence or hex code:
Tab (0x09):
Tab converted into space (0x20) after restart:
This does function as expected until restarting MB.
Unless support for Unicode Control Characters is within scope, is there any possibility for a fix for this particular issue? Tabs are extremely useful when copying data to spreadsheets OOB, without having to alter delimiter settings.
