Author Topic: Change search engine when searching for Lyrics (Right clicking lyrics)  (Read 994 times)
heyman111
So when you right click the lyrics, you can "Google Search". Was wondering if it would be possible to add DuckDuckGo or any other search engine instead.
You can create your own. You set them up under Preferences > Internet. You then enable them in the Track Information panel.
