Author Topic: Love & Comment Tag bug  (Read 1305 times)
wasp
If you 'Love'  (or favorite) a track and right after you put any text in the 'Comment' tag and hit save, the 'Love' gets deselect.
I don't know if this is intentional.
I can't reproduce this behavior. If you are not using the Store version, try updating to v3.4 which is available from the first forum topic
wasp
I'm using 3.3.6889 portable.  v3.4 is not available as a portable as of yet, correct?
You can do a patch update. Grab 3.4 from my signature.
wasp
Thank you phred. I'll update and post back
wasp
Still occurring. If its something you would like to look into I can send you a clip.  It's only a minor annoyance at best. I can easily add any notes in the Comment field first, save - and then click on the love icon.
i guess a clip could be helpful and also do you have love status sycned to last.fm (in the plugin preferences when last.fm  is enabled)
wasp
last.fm is not enabled
Clip
Last Edit: January 22, 2021, 08:14:24 AM by wasp
Thanks for the clip which helped me solve the issue. Its fixed for the next v3.4 update which i will post later
Last Edit: January 23, 2021, 05:48:30 AM by Steven
wasp
No problem. Likewise, thank you for the quick fix.
Tried the patch and works great.
