Author Topic: status bar shows song name and artist name very close.  (Read 1344 times)
user73
I have seen other skin screenshots  and they look fine but my MB shows song name artist name very close.not sure why.
Make the window wider.
Assuming you're not running full screen, the same way you make any window wider. Hover over the left or right edge and when you see the two-headed arrow, left-click and drag.
user73
check the naming templates used in Preferences/ Now Playing/ playback
user73
Spot on    :)
I had this problem for so long just did't get time to post.
thank you very much .
