Author Topic: File rescan removes the track ratings??  (Read 1106 times)
electro
I don't remember this happening on past versions. I'm using the version 3.4.7628 P. Please fix this bug.
Update to the latest patch (see my signature) try again and report back.
electro
Thanks. Just before seeing your post I re-saved all my rated files after activating the option Store Ratings in the Music File from Preferences -> Tags (1). Many of my older ratings existed only in the MB database and a file rescan could simple erase them.
EDIT: I tested the patched version and the issue is fixed.
Last Edit: January 01, 2021, 06:59:46 PM by electro
Glad to hear you've got it squared away.
