I have a new SD card that i'm trying to copy music onto from an old sd card. The new one is connected to my mp3 player, which MB registers as a connected device (through a Fiio M11), while the other one is connected as a removable drive.
I've tried a few different options but none of them appear to work without running into issues.
1. Since both cards are readable in the system, I thought simply using the auto organize feature can just move the music from the old card to the new one (via Fiio). This didn't work, as I kept getting repeatable error messages (assuming it was due to the path not being found). Note: Fiio is connected in windows via MTP, showing up as a phone.
2. Next I tried loading both paths via the import library option, and storing the music from the old drive into a playlist and syncing a small batch of files to the new card, again registered on my Fiio as a 'device' in MB. While I was able to copy the music over, duplicates were stored on the device As a side note, .I noticed in general, MB doesn't track duplicates as it pertains to exact tag matching.
Now I'm not sure what else i can try. I want to see if perhaps using the new drive via a card reader, would allow me to now see both cards as removable drive and not only one of them (with the other being a connected device), but I would have to obtain one first. Any other options I can try?
