Author Topic: Plugin that exports Playlist Trackfiles with sequence numbers in Playlist order  (Read 6068 times)
airider74
Hey All,
I've got a car radio that doesn't read M3U files but does understand file structure and organization.  Based on this I would like to create a plugin that can read a playlist, export the appropriate mp3 files in the playlist to a separate folder and add leading numbers to each file that align with the track sequence in the playlist.
Right now I have to do this with a program like Bulk Filename Utility using RegEx and it is a pain.
Doesn't MB do this on its own when synching each playlist to its own folder?  Just ignore or delete the actual playlist.
Last Edit: December 22, 2020, 02:52:29 AM by frankz
