Hey, all.
The organizing library files is a really great and helpful feature.
However, is there a way to set restrictions on it? That is, defining which files should NOT be automatically organized.
I'm able to see that I can define an exception to my file organization rule, but this appears to just change
how the files are organized, and not
which files should be organized:
I want it so that all files that I send to my music library via inbox are automatically organized,
except if their Folder Name is 'TestFolderName'. Is that possible? How would I go about doing that?
Any help is greatly appreciated!
EDIT: I don't want to necrobump this thread, but after a couple weeks, I found a potential solution! (Requires multiple drives, though). I just separated the files that I don't want automatically organized on a separate drive and they aren't organized! Problem solved!
