@The incredible Boom Boom:
Thank you for explaining this feature.
However there is still a problem:
Pls follow the steps below:
1. I mark a certain playlist
2. I right click on "Playlists" tab and select the previously Custom Layout (= with Manual Sort order!). See attached snapshot 1
3. I mark another playlist
4. I right click on playlist column header and select another sort order (e.g.Artist-Title)
5. I switch back and selected again the playlist from step 1
The previously assigned Custom layout was overwritten by the sort order I assigned to Playlist Layout sort order from step 4
Thats bad.
It seems to me that selecting a custom Layout is global for all Playlist
I want a certain Sort Order ("Manual") for only one certain Playlist.
This Sort order should be kept regardless of which sort order I specify later for other playlists.
When I revert back to the special playlist then automatically Manual sort order should be active
I expected a layout/sort order definition per playlist not via "Playlists" tab but as on option in Preferences dialog of this playlist X.
But when I go into such a Preferences dialog of Playlist X my custom Layout does not appear (see attached snapshot 2)
So whats wrong?
