Author Topic: API - NowPlayingList Size  (Read 6370 times)
Spicefly
Hi
I'm adding tracks and trying to limit the size of the NowPlayingList to remove older played tracks.
I had a look at mbApiInterface.NowPlayingList_IsAnyPriorTracks() but this just return true/false and I can't seem to find a function to return the size of the list?
Thanks in advance
There is a way:
NowPlayingList_GetNextIndex(Integer.MaxValue) will return the count
Last Edit: December 12, 2020, 10:44:48 PM by Steven
Spicefly
Thanks for your help, in the end I used the following code which initial fiddling around seems to work and keeps the tracks being the current playing position in check;
                      // Keep Queue trimmed down
                                while (mbApiInterface.NowPlayingList_GetCurrentIndex() > 5)
                                    mbApiInterface.NowPlayingList_RemoveAt(0);
All the best
