I've looked around the different settings and all I could find is just toggling the status bar info on/off and switching between HH:MM:SS and decimal display for the duration of the selection.
The format of the status bar info is consistent in its format:
[extent], [file size total], [duration], but with that the exact number of files in a given selection is only shown when
selecting tracks directly, otherwise it
shows numbers of albums instead.
Occasionally, it would be helpful to also see the number of tracks in a selection (in addition to the number of albums) no matter what "level" a selection is made in. Is it not possible, or have I just missed some configuration option in the preferences?
Admittedly, I'm running a bit outdated version (3.2.6827) of MusicBee, so I guess this might very well be something that's already been introduced since?
Thanks!
