@The Incredible Boom Boom
Cheers for this though not exactly how I was hoping it would work it is good enough so thank you very much for this I have have been trying to figure this out most of the evening and was getting completely fed up with it!!!
another quick question do you know if
https://www.musicomh.com can this be set up to link to album reviews at all or not, my guess is on it not been able to.
and finally I guess i an not able to make a link specific for an album review to be clickable. What I mean by this is for example I wanted to add this web address
https://www.sputnikmusic.com/review/32200/The-xx-xx/ to either a custom field or the comment field so it shows like a hyperlink would when it in the post on for example the above on a forum.
I hope that last bit makes sense as it does in my mind but might not to others!!
if not i will try and explain it better.
Thanks again
Boroboy383
