Author Topic: How to disable MusicBee entries in WinExplorer context menu?  (Read 1645 times)
clsven
When I right-click on a folder in Windows Explorer then there appear 3 entries:
Play with MusicBee
Queue Next in MusicBee
Queue Last in MusicBee
How can I disable these context menus?
clsven
Hmm, with this settings I delete the context menu AND the file associations.
But when I double click on a *.mp3 or *.m3u file then MusicBee should be lauched. Thats my intention
I just want to get rid of the context menus.
Any solution?
From the choices at the link psychoadept provided, I would suggest starting with ShellMenuView, have had good luck with several of the NirSoft free utilities and most are portable (https://www.nirsoft.net/utils/shell_menu_view.html).
clsven
Ok, I played around for a while with tools like ShellMenuView and others.
Yes I can temporarily disable Musicbee context menus.
But when I install a new version or under other circumstances MusicBee automatically re-enables these Context menus.
In ShellMenuView some of them cannot even be disabled
These entries are annoying.
Is it really too difficult to add a simple stupid new option to MusicBees configuration to allow disabling context menus FOREVER (and keep *.mp3 associations for double clicking)?
Is there an official feature request email address?
Last Edit: September 16, 2022, 11:59:11 AM by clsven
post request on wishlist board of the forum. or disable mb integration with explorer, right-click on any .mp3 file, "open with", musicbee (tick the checkbox to always use mb to open .mp3 files).
