Author Topic: Language tag separated into multiples, but doesn't show up on main panel  (Read 1136 times)
djimy
When selecting Language tag, they are separated into multiple tags, but selecting one of those tags will not show any album that have more than one tag.
For example, if I have a song tagged as "Artificial; Aduanic", then "Artificial" and "Aduanic" will show up as different tags in the list, but when selecting "Artificial", only songs that are tagged "Artificial" and nothing more will show up in the main panel.
https://imgur.com/a/FIovkcL
djimy
Here you go:
edit:
link removed
Last Edit: November 30, 2020, 10:58:44 PM by Steven
matt77hias
This functionality last worked in version 3.5.8447.
This functionality broke since version 3.5.8698 (latest version as of writing).
Going to Music Explorer for the Now Playing song with multiple languages directs to the corresponding multi-language panel. I cannot recall the original behavior, but this seems correct to me as opposed to selecting only one language. (It is, however, worth noting that one cannot go to a multi-language panel directly via the navigator afaik. The navigator only lists separate languages.)
Selecting a language in the navigator only shows albums containing at least one song in the given language only. In the below image, the navigator indicates that one album contains a song in Mandarin, but no album is listed, because the actual song is in English and Mandarin. This has changed between the aforementioned versions.
Last Edit: November 20, 2023, 07:11:46 PM by matt77hias
