Author Topic: Musicbee and Google Play music backup  (Read 3869 times)
adamf
  • Hello and thanks in advance for any help you give
Hi all,
My musicbee library was automatically backed up to google play music. Will it continue to do this now this service is closing and is going over to youtube music?
I haven't seen any posts on this topic and so I thought to ask.
Are there any steps I need to take?
Thanks in advance,
Adam
That's really a question you should investigate on Google's side. If the files are also on your local computer then MusicBee will do what it has always done.
adamf
Just in case anybody else has the same question...
Youtube music does not automatically sync with your music folder like GPM did. If you want to upload music, you will need to choose the option in settings and choose the music files you want to upload or drag & drop the files into youtube music app on your PC.
Thanks,
Adam
MujikMusical
Thanks,
Adam
Thank you for the clarification. It is very helpful especially to me.
