Author Topic: The "Search and replace" window blocks the main " MB " window.  (Read 1874 times)
Sofocl
When you open the "Search and replace" window, the main MB window is blocked;
Request:
1. Do not block the main "MB" window when opening the "Search and replace" window.
2. The "Search and replace" Window should dynamically change to the "MB" selected in the main window (as it happens for example with the "edit", "tag inspektor" window");
Sorry for my bad English.
Sofocl
Bamp.
And in order not to create a new topic, I will write here, unlock the "Search Internet for Picture" window as well, I often want to compare the new and old image, but the MB window is blocked;
It seems to me these are small but very useful changes that should not break anything, make it heavier, but only improve the MB, and I think it's easy enough to implement :)
Last Edit: January 20, 2022, 06:19:56 AM by Sofocl
