Author Topic: Je ne trouve pas ma collection de musique  (Read 2468 times)
You can select any number of files, right click and use Send To > File Rescan.
You say you got this computer recently. I wonder if that has anything to do with the permissions problem. Did you a copy a lot of files from another computer?
cyril_ansi
Yes I made this, but it not resolve the problem.
He still has this error message :  https://imgur.com/a/gl8XiQV . I have no doubt you know this message but in case I translate " File's save--> access refused"
I think it's related to a permission problem. Yes I took all audio files with USB key on another PC.
Thank you very much for helping me, because i would really like use this application despite there difficulties (and sorry for my spelling mistakes ;) )
You're welcome, thank you for being patient with the process!
I suspect that this or something very similar is the problem: https://www.computerhope.com/issues/ch001983.htm
If that guide doesn't help, I've also used this app in extreme circumstances, when nothing else worked. Use with caution! https://www.iobit.com/en/iobit-unlocker.php
cyril_ansi
What is weird and what I forgot to tell you, is that the first time I opened MusicBee a few days ago, I COULD EDIT, but since I could not find my collection of music (cf initial problem of the conversation), so I did as you told me, ie uninstall MusicBee and install the portable version. But since I did that, at least I can listen to music on MusicBee but so I have this problem of not being able to edit my tracks.
I did you first method and it still doesn't work...
I'm not actually surprised that you're having a different access problem with the portable installation. I'm not experienced enough iwith it to have all the technical words, but MusicBee as an installed app has different access rights than as a portable app (which is related to the fact you don't have to give administrator permission to install the portable version). This is really a windows issue, though, so I don't know how much more help I can be.  My only other suggestion would be also moving the music files themselves to a different location; I don't know if that would fix it or not.
cyril_ansi
I think I roughly understand the problem. I think I have found the "solution", which is to redownload all my music (around 1000 for the moment) ... I only see these solutions without being too complicated
That sounds like it should work. Let us know!
cyril_ansi
Even like that, it doesn't work ...
If this is really a Windows problem, do you know a forum where I could be helped please?
Do you think there might be a difference if I use the Windows 10 version of MusicBee?
There is no Windows 10 specific version of MB. It works on Windows 7, 8, and 10.
Check out the MusicBee Wiki.
Do you mean the store version? I wouldn't recommend it, then you won't be able to install the most recent updates.
