Author Topic: Adding lyrics to songs (downloaded to iOS device)  (Read 2072 times)
robinsiebler
I would like to add lyrics to songs and have them embedded somehow so that they will show up on my iOS device. How would I go about doing that? I am using Windows 10, and the latest version of MusicBee.
Thanks!
You can use the LyricsReloaded (Updated) plugin to get your lyrics. If the Apple device reads embedded lyrics in MP3 files, then they should show up. If you don't know the answer to that I suggest you find an Apple forum and ask over there.
