Author Topic: "upmix stereo to 5.1" does it change audio in anyway, or only the routing?  (Read 3329 times)
SurfRat
I have a SoundBlaster Z (5.1 audio). I have 2 monitor type speakers and 3 surround type speakers and a sub connected. I wish to play stereo music via MusicBee. If I use MB in stereo mode my sub has no audio. This is a problem with the sound card as it does not have 2.1 audio.
To get audio out my sub I can set the sound card to 5.1 and use MB's "upmix stereo to 5.1" with the surround speakers switched off. This works and I effectively have 2.1 audio.
I want to know if the upmix setting changes the audio in any way?
Does it only route the audio to the other speakers?
Thanks
Mark.
SurfRat
I did some research into the BASS audio library https://www.un4seen.com that MB uses.
There are two ways to do up mixing:
1. simple/efficient way to do that is to mirror the channels via BASS_ASIO_ChannelEnableMirror.
2. Using a Matrix. https://www.un4seen.com/doc/#bassmix/matrix.html
Both just mirror the channels with no audio manipulation.
Until I hear otherwise I am summing the audio is mirrored to the other channels and no audio manipulation takes place.
