as often in MB - this already exists, but is a tad hard to find (if by Column Brosers you mean the spreadsheet like Tracks view...?).
Have a look here:
On top of the panel there's:
Tracks \/
Press the: \/
Then:
Custom Views -> Copy Current View Settings to...
Save .mbv file in place
Every saved file then can be loaded into a tab independently (i.e. I use different Custom View files vor Playlists VS Music Lib....)
Hope this helps & is what you're looking for.
c.
