Author Topic: Make editing playcount update the lastfmplaycountcache.dat data  (Read 85 times)
biggy_wayn
Sometimes the lastfm plugin gets my playcount totally wrong. Example:
Last FM:
Now, I want to manually fix it, so when I right click the song, press Edit, and press Properties
If I manually change it to the correct value (8 in this case) and hit save, then close MusicBee and re-open it, it undoes my changes and changes it back to 65 through the lastfmplaycountcache.dat
Can you make it so that if I do a manual change on the playcount, it updates the value on the cache file as well?
