Hey all,
Have been successful in usb and wifi syncing files through--but for some reason the ratings and playcounts never take. I initially tried Poweramp, but then to see if it was an issue with MusicBee, I tried GMMP as well, which became even stranger as it then updated only random songs.
I've tried:
-setting preferences to "store ratings in the music files"
-change sync setting to "force the use of ID3 v2.3for saving mp3 files
-saving playlist format as M3U8
-using Full Rescan in PowerAmp
-using both USB sync and MusicBee Wifi Sync
Not sure what else to try--and I'm generally out of my realm here. For the few tracks that did sync rating for GMMP, I'm not sure what was unique about them, and I haven't been able to get either app to sync new ratings back to the PC.
I'm using:
PowerAmp Build: v3-build-884-arm64-play trial
Device: samsung galaxy note 10
Android: 10
MusicBee (V 3.3.7491; with Windows 10
I appreciate whatever help you offer!
