Author Topic: problems with scrolling  (Read 1197 times)
SimonZ
whenever i scroll down I the screen kinda locks up
Only happens scrolling down. Scrolling up is fine.
Last Edit: October 23, 2020, 02:18:25 PM by SimonZ
Does it happen when the tag editor is not displayed?
and are you scrolling with the mouse wheel or dragging the scroll slider bar?
I will need a link to your settings file (help/ support/ view settings)
Last Edit: October 24, 2020, 08:21:30 AM by Steven
SimonZ
I'll send you a PM with a link to the settings file. The scrolling happened with wheel mouse - didn't try the scroll bar.
As for the tag editor, I can't tell you right now, because I can't reproduce it! But it has happened several times before, so I'm sure it'll happen again, at which time I'll let you know.
I wasnt able to reproduce it with your settings. The issue will likely be because the main panel is not correctly sized with the edit box displayed ie. the edit panel covers some or all of the main panell. I dont know why that would happen but perhaps after you maximised or restored musicbee.
