Author Topic: Sort by menu - merge default & custom to make 16 choices  (Read 1026 times)
fred
If you select the 'Sort By' drop down and 'Define Custom Sorting ...' you are presented with a window where you can edit the 8 custom sort slots but there is no way to edit the other 8 pre-defined sort slots. I have never used any of the pre-defined slots but on occasions have used all 8 custom slots and wanted a ninth. So my suggestion is a 'Sort By' dropdown that allows you to edit all 16 sort slots
I think it makes sense to keep a common set of defaults, lest people who don't know what they're doing start editing them and get confused or even break something.
It sounds like what you really want is just the ability to have more than 8 custom sorting sets.
