Author Topic: Proliferation of "Artwork" files SOLVED  (Read 1529 times)
clatix
This is a potential bug report.
I use MB version 3.4.7547.
I have each album in its own folder. So 100 albums 100 folders.
Conditions:
If in Tag(1)/Artwork/copy to the same folder as the music file ad name as: (both ticked and non ticked) there is for example "<Album Artist> - <Album> - Cover.jpg" (but the same also applies with different fields, for example: "<Album> - Cover.jpg")
And if in Edit/Artwork (and in the folder) there is the same file "<Album Artist> - <Album> - Cover.jpg"
Then:
If I change the content of one of these tag-fields in Edit, eg. <Album>, then a new file is created in the folder bearing the new value of the tag-field.
If I modify one of the fields again, eg. <Album> again or <Album Artist>, yet another file with the new values is generated. And so on ad infinitum.
Expected behavior:
No change in the file name or just changing the file name and NOT creating a new file.
Thanks for the attention.
Last Edit: October 18, 2020, 01:46:23 PM by clatix
Thats fixed for the next v3.4 update. I will post a link later today
Last Edit: October 18, 2020, 07:24:23 AM by Steven
clatix
