Author Topic: New playlists requests  (Read 308 times)
It's handy that you can create a playlist by dragging files to the playlist node. It would be even better if you could do the same thing by dragging to a specific folder and have the new playlist appear there. And/or have a <New Playlist> option for the folders in the right cilck menu.
A tiny thing but seems logical: right now, if you create a folder it appears after all the other folders AND all the other playlists. Since folders are sorted before playlists, shouldn't it appear before the playlists?
Latest beta patch (3.4)
you can now drag files to a playlist folder and MB will create a new playlist in that folder
This is working great, thanks! Big time saver; I'm trying to convert almost 100 "albums" to playlists, while also keeping them organized and getting them all locked. Oh boy!
