Author Topic: How to get a library selection event?  (Read 8770 times)
codingduo
Hi there,
we're developing a plugin which creates a panel with moods which allows the user to select the moods he wants to add to his files by simply clicking a checkbox (see screenshot below).
We can update the panel by playing a file (double clicking in the library panel). Now we want to listen to a single selection event on the same panel.
To be more concrete:
The user selects a file in the library panel and we want our moodtagger panel to update.
Do you have any solution for this?
Thank you in advance!
Screenshot:
https://imgur.com/1EcP9rv
Seems an obvious thing to have but its not supported. I will add an event to the next v3.4 beta
codingduo
Thank you for the quick response! Looking forward to the next beta.  :)
If you add the following void function to the Plugin class, MB will detect it and call it whenever the selected file changes
public void OnSelectedFilesChanged(string[] filenames) {
codingduo
codingduo
Everything works as expected except for the deselection (e.g. CTRL+Mouseclick) of list entries in the library. We appreciate if you can add this as well. Thank you in advance.
I am not able to reproduce any issues with de-selection and see no reason for it not to work.
If you are sure it is not working, then can you provide a set of steps with a screenshot as well
codingduo
Hi. So we implemented the OnSelectedFilesChanged method and added a breakpoint. And in debug mode, we did not get a break at this point when we deselect one of the entries on the library panel. We recorded a short GIF for you. Hopefully it makes things clearer to you.
https://i.imgur.com/QFQBibX.gif
Kind regards
I still cant reproduce this. Can you send a link to your settings file (help/ support/ view settings)
