Author Topic: Is there an option when searching internet for picture, to always embed in file?  (Read 1710 times)
e8ghtmileshigh
Can I change the setting somewhere so that it automatically embeds instead of having to click that checkbox every time?
Yes. Make sure embedded is selected as the artwork storage option in Tags (1) preferences. https://musicbee.fandom.com/wiki/Tags_Preferences
You may also want to move Embedded to the top of the list for artwork display.
If you don't want the popup to display at all, you can untick "confirm picture storage options when adding artwork" in General Preferences, but beware that in that case, it will also take the first artwork it finds rather than letting you choose between sources.
Last Edit: September 27, 2020, 12:35:38 AM by psychoadept
e8ghtmileshigh
Yes I have that option checked, but every time I search for, or copy and paste an image I need to check the embed box.
you ticked the "embed picture in the music file" option on the left side of the Tags(1)\artwork settings?
e8ghtmileshigh
In that case there should be no reason for it not to work. Trying now its working fine
Please post a screenshot of your Tags (1) settings.
Is this happening for all files, or just specific ones? If specific files, are they be marked Read-Only?
What format are the files?
e8ghtmileshigh
Version 3.3.7367
Installer
All files.
FLAC and MP3
the only thing i can think of is if you are editing files on a device then the device sync settings would be used for how the default artwork is stored
Yeah, if the files already have artwork then it defaults to the original storage method.
As phred said, screenshots might be helpful to show us your settings and process.
