Why can't you just open the playlist in MB, select all the files in it, and hit the delete key? Make sure you do "Delete from Library Only" and not library and computer if you don't want to delete them from your computer, too.
Hi, welcome to the forum!You can do a search for "Playlist has a value", and it should show you any tracks that are in static playlists. It doesn't sound like you'd be dealing with auto playlists here, anyway.
