Author Topic: Removing Input Plugins  (Read 2241 times)
patricianvidya
Hey all,
I'm attempting to remove some Winamp input plugins as they seem to be causing some issues. However, for the life of me, I cannot figure out how to to this. Any help would be greatly appreciated.
Using a file explorer delete them from the directory you put them.
patricianvidya
Already done (I had imported the DLLs from my Downloads folder and have since deleted everything inside it), but the plugins still appear and I can even still configure them. I also tried searching through the MusicBee directory with no such luck.
check the MusicBee\Plugins folder and depending on how you imported the plugins the dll's could also be in C:\Users\<your id>\AppData\Roaming\MusicBee\Plugins
patricianvidya
Ah, it was in the AppData folder. Thanks for the tip!
