Author Topic: Exporting playlists (to Emby)  (Read 408 times)
lander
I want to create M3u playlists that can be read by Emby.
I have the music in a pc with Umbutu and using Musicbee from a pc with W10.
After playing with the settings for a correct export to be read by Emby  i found that i need to check relative file paths and use unix path convention.
The problem i am encountering is that if i select files from the menu Folders i get this  ../  at the beginning of each song in the playlist, I export it and it can be read by Emby but if i add the songs to the library from any other part of Musicbee,for example ,from a Genre or a search ,or anything different from the menu Folder i get something different : //NAS/ (Nas it's the name of Umbutu pc),which can't be read by Emby.
Why are the outcomes different ?
Thanks!!!
lander
Correction : "but if i add the songs to the library from any other part of Musicbee",
 it should read
"if i add the songs the playlist from any other part of Musicbee"
