Author Topic: New Laptop - Import settings?  (Read 1061 times)
jasongnome
Just got a new laptop, downloaded the newest version of MusicBee, installed no problem. All my music is on an external drive so setting the library up was easy as well.
I've also managed to  get it back to my custom sorting etc.
However, I customised quite a lot in my MusicBee, is there a way of exporting settings from MB on my old laptop and then importing them on my new one to save having to redo everything manually (which I can do but it's just time consuming)?
Preferences > Edit > Saved Settings > [Save][Load} Settings Snapshot. Note that file paths on both PCs must be the same.
