did you try rescanning the files (right click/ send to/ rescan files)if it still shows 0, can you send a link to one of the problem files
The file is missing the information for the total number of samples and hence MB and other players cant work out the duration. It otherwise seems fine - all other information looks ok. So its a bit of a mystery and nothing i can do
