Author Topic: Musicbee not updating to latest version.  (Read 3060 times)
user73
Hi
I tried to update 3_4_7547 but when i check MB in about it is still showing version 3.4.7481
I downloaded this one http://www.mediafire.com/file/1lem2lbf7rlpi09/MusicBee_Setup_3_4_7547.zip/file
and extracted the file within MB.
That's a setup file. You have to extract the .exe to your MB directory and then RUN that to start the installation.
user73
Yea man thats what i did...
Sorry i was not clear earlier.
Extracted MusicBee_Setup_3_4_7547.exe to MB folder and then ran file  as administrator.
Try whitelisting the entire MB folder in your anti-virus application.
user73
thx for helping..
I tried as you suggested but it didn't work.I even pause Antivirus for 10 minutes and still not success.
I'd suggest manually installing the patch from phred's or my signature, instead.
user73
Yes it worked...
i downloaded from ur link psychoadept...it is now 7558..(i know its beta).
Thank you guys.
Great, glad that got it.
Are you running a regular or portable installation, out of curiosity?
Hmm. And you didn't get any warnings or error messages about running the file from within the MB folder?
That's really odd. Maybe next time try running it from a non-protected folder (Downloads or something) and not as an administrator? I think it only needs to be in the MB folder if it's a portable installation. Or just keep using the patch. :)
user73
Well i just did again.this time i tried to run to from other driver.but nothing happens.
and thx again for helping.
Last Edit: September 12, 2020, 09:33:14 AM by psychoadept
If you have a regular installation, shouldn't this be installing to C:\Program Files (x86)\MusicBee rather than to your E drive? Can you find the files it says it put in E:\My\MusicBee?
Last Edit: September 12, 2020, 09:35:43 AM by psychoadept
user73
Programs that i use most i prefer to install in other drive in case something happens to C drive.I been doin this for ages.Thats why it is in E drive.But i didn't have this problem of update before.Which means till version 3.4.7481 it was still updating fine with the same process.
